Can't get drivers side axle out.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I have spent the better part of today trying to get the driver's side axle out of the transmission with no luck. I tried using the nail puller pry bar, a ball joint separator, and a loaner axle proper from AutoZone following instructions from this forum. I tried rotating the axle a bunch of times to different angles, and nothing worked. :cry:
What do I do now?
2002 v70 X/C 288k miles
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
slide hammer is how we got a difficult one out.
Has thanked: 1611 times
Been thanked: 4075 times
Cold chisel wedge between axle and transmission flange. You need to place it carefully so you don’t gouge anything. Get the wedge part stuck between casting and axle and one whack with a 1.5 kg hammer will pop it
02V70
Post by 02V70 »
jonesg wrote: 31 Dec 2023, 03:26 slide hammer is how we got a difficult one out.
Do you have an image of a slide hammer, or a link to one that will work? Autozone has something I can rent, but I'm not sure if it fits.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
02V70 wrote: 30 Dec 2023, 22:23 I have spent the better part of today trying to get the driver's side axle out of the transmission with no luck. I tried using the nail puller pry bar, a ball joint separator, and a loaner axle proper from AutoZone following instructions from this forum. I tried rotating the axle a bunch of times to different angles, and nothing worked. :cry:
What do I do now?
You can use a slide hammer and vice grips to clamp onto the inner cup or I found the method is the linked Youtube video interesting; he uses vice grips and the axle itself as the slide hammer. Some axles come out easy and others can be a real pain, just depends on how the circlip holding the axle in place releases. If the spline area beveled edge or the circlip is worn or rusty it doesn't squeeze the circlip inward well enough so the release becomes difficult.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
abscate wrote: 31 Dec 2023, 06:06 Cold chisel wedge between axle and transmission flange. You need to place it carefully so you don’t gouge anything. Get the wedge part stuck between casting and axle and one whack with a 1.5 kg hammer will pop it
No to cold chisel.
Knock on following tool and rotate; the circlip needs coercing... it will release; else see this thread viewtopic.php?t=62641
02V70
Post by 02V70 »
I have tried using a pickle fork with no luck. Maybe I am doing it wrong? Can you explain exactly how you used it?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
2003 XC 70 (sold)
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I’ve found two pry tools at once helpful too—seems to keep the shaft/circlip straight in aiding the removal.
08 C702.5T (sold)
The non-Swedes:
jonesg
Post by jonesg »
02V70 wrote: 31 Dec 2023, 15:37
there must be over 50 videos on youtube of a dozen different ways.
