I have a volvo v50 which i bought hoping i could fix.... seems to be a money pit.
couldnt find an ecu kit anywhere, eventually i took a gamble fitting an auto kit to my manual car.
ecu, cem, scu, clocks.
previously car was stuck with immo try again.
this time it says immo try again * but it actually spins over! "
can the steering lock module cause this? as its the only part i havent changed nor coded. ( could an emulator solve this) if so would this possibally cure the immo issue, i find it strange with immo active it still wants to start although previously the immo inhibited starting too.
VOLVO V50
wharfedale
- Year and Model: 2009 v50
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 22 times
What do you mean when you say "ecu kit"? Have you programmed the ecu to your car? They aren't plug and play.
-Eric
-Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
