Volvo v50 strange technical issue
wharfedale
Year and Model: 2009 v50
Post by wharfedale »
Ignition on : engine not running, pedal stats in Vida shows me pushing pedal 0% to 100% …. I start the car … pedal doesn’t respond , it stays at 0%
But let’s say I start it with the pedal already down to the floor , stats show pedal at 100% it try’s to increase revs but sucks , lumpy it sits somewhere random like 2k 2.5 sometimes 3k or won’t even start at all .
As you come off the pedal Vida sees the percent dropping , if you press it back down percent never increases , for example , start car at 100% , come off by 50% and push throttle back to the board , it will remain at 50% … if you come off below 50% the value will climb down , note it says signal to high on sensor voltage circuit 1 , and many other sensor and pedal errors although pedal works fine when it’s not started
mathwilton
Year and Model: Volvo XC40 2021
Post by mathwilton »
wharfedale wrote: 17 Feb 2024, 07:00 uno online
Same issue. Did you find the solution?
wharfedale
No unfortunetly, tomorrow ill try cut the cable thats feeding it power, expecting 7.35v instead of 5, ill manually feed it 5 to see how it reacts since its the signal to high ( voltage ) thats causing the pedal to have issues
RobsS40
Year and Model: 2006 S40 T5 AWD
Has thanked: 2 times
Been thanked: 7 times
Post by RobsS40 »
Is the car "drive by wire"- no mechanical connection between pedal and throttle? If so, have you checked throttle body for carbon or other ways the throttle plate doesn't move freely?
