So I have been having issues where a vacuum line will pop off of either the vacuum tree, or the pressure switch for the water / meth injection.
This only happens at WOT, which at this point can hit a little over 20psi. Regular hose clamps won't clamp 1/4' lines very well, and space is tight on that tree, so I have had to resort to small braided steel wire which I twist tight. That works, but is not a very "elegant" solution.
I'm not sure if an Oetiker clamp would work on a line that small either. Any other ideas ? I seem to remember seeing some sort of twisting wire tool, but don't know what it was called.
Vacuum line clamps
- Has thanked: 2854 times
- Been thanked: 1332 times
I redid most of my 850's vacuum lines with Gates lines, about 15 years ago. I blew my intercooler at around 17psi, so they're good to that at least. More good than the stock intercooler.
Those lines were at least 4x more mass than the light, white factory vac lines were. I'll look for my writeup on that.
Gates 3/16th line viewtopic.php?p=233700#p233700
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I really dislike those white plastic lines. Who thought those would last in that environment?
Ah... design decisions. Sigh.
- BlackBart
I broke that plastic vac tree piece long ago and thought oh no, now what! But it was like $7 at the dealer. But that’s when I dealt with the little elbows and that white line.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
The little spring steel pinch clamps won't hold. I wish someone would make a billet vacuum tree with slightly barbed posts.
That would solve a few problems.
Thanks for that link. I'm using silicone vacuum tubing which might be part of the issue. That stuff is a little slick by nature.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 987 times
- Been thanked: 1075 times
A very small Zip tie in your favorite color?
- Sveedy
Not sure, but this might be what I was thinking of.
https://clamptitetools.com/
A bit pricey from the source.....
1999 V70 GLT
1999 V70 GLT
- 38 Replies
- 13766 Views
Last post by 454cid
- 26 Replies
- 7010 Views
- 691 Views
Last post by volvolugnut
- 13 Replies
- 1697 Views
Last post by vtl
- 886 Views
Last post by EstVolvo
