Timing Belt Question
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
volbul2
Year and Model: 2004 XC70
Has thanked: 1 time
Been thanked: 2 times
Post by volbul2 »
I recently replaced the water pump and timing belt of my 04 XC70 165k. First time I've done this job. I was losing coolant from the water pump. Mechanic who did timing belt 70k miles ago did not fully screw-in one of the 7 bolts of the WP and coolant must have leaked thru gasket. Anyway, I believe I replaced and installed everything correctly (TB, WP, Tensioner and idler pulley and drive belt and tensioner). While the old belt was still on I turned the crank to TDC and marked the setting in various spots. Before installing the new TB, I noticed the intake cam was forward by 1 or 2 teeth. I moved it back to the TDC mark and installed the TB. After job was done, car started fine and runs fine. No messages on dash. I've also driven at least 100 miles since and ran fine. Yesterday however as I was driving around town I heard a kind of intermittent faint rattle coming from the front. After I pulled in to my driveway I kept the car running and popped the hood to listen closely but engine was nice and smooth. No rattle.
I googled symptoms of improperly installed TB and most that came up was valve issue. How do I check if I did the job correctly? Thank you.
04 Volvo XC70 5L 145k Ruby Red (acquired 9-30-17)
07 Honda Accord V6 130k Silver
07 Honda Accord L4 130k Bronze
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
These engines are not timed at TDC, but slightly before for crankshaft(there is a notch when you remove the crank pulley/harmonic balancer. The intake camshaft if with a VVT hub can move independently(within a limited range) from the camshaft itself.
volbul2
Has thanked: 1 time
Post by volbul2 »
Sorry but I don't know what you mean by "not timed at TDC". One thing I forgot to mention was I verified the timing marks again at least 2X after I installed the TB by turning crank. The cam marks lined up at TDC.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
In the old days, engines were timed and valve trains set based on the reference position Top Dead Center (TDC). This was the position when the first cylinder reached the fully extended position at the top of travel.
If you set the belt to time the valves based on the timing mark on the crank and the paint marks on the timing belt, you should be good for valve position.
The rattle may be some other thing you left loose.
