2002 V70 XC
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Jrv7
Year and Model: 2002 V70 XC
2002 V70 XC
Post by Jrv7 »
Hello everyone I'm new to this, but I replaced the timing belt, water pump, cam seals, and the brake booster on my 2002 Volvo V70 XC, and it won't start, it did a weak half crank and nothing, I checked timing again. It was on the timing marks, spun freely it didn't get stuck. But it won't even crank anymore. I replaced battery because it rated 11.8v and it wasn't holding a charge either. But nothing just clicks. What do you think?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Jrv7 wrote: 11 Mar 2024, 23:54 Hello everyone I'm new to this, but I replaced the timing belt, water pump, cam seals, and the brake booster on my 2002 Volvo V70 XC, and it won't start, it did a weak half crank and nothing, I checked timing again. It was on the timing marks, spun freely it didn't get stuck. But it won't even crank anymore. I replaced battery because it rated 11.8v and it wasn't holding a charge either. But nothing just clicks. What do you think?
If it just clicks it's most likely the solenoid in the starter. A good Battery voltage should be around 12.6 Volts with 12.8 being normal.
The starter motor could be good but solenoid is out so unable to push the pinion gear into the flywheel.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
compare voltage at the battery to what you get at the big red wire on the starter.
Jrv7
Post by Jrv7 »
It is a bad starter. I did check voltage, voltage was good. I jumped the starter nothing. I hit the starter while I had someone start it up and it started right up. Thank you for the advice, really helped out!
