p0420 & p0430 on volvo xc90 2012 Topic is solved
EgoziAlon
Year and Model: Xc90 2012
Post by EgoziAlon »
I have a Volvo xc90 2012 3.2.
just found out i probably share the same problem as many other 3.2 owners do: "high oil consumption" and catalytic converter failure (p0420 and p0430 codes). another thing i didn't see anyone wrote about, is about the plugs. mine were covered with white sediment. some mechanics told me that its the burning of oil which comes out of the rings and some mechanics told me its the uneven burning of gas since there is A poor mixture of gas and oxygen. my thoughts are that maybe poor mixture could be since my converters are bad, the o2 sensors are getting bad reading and engine is using poor mixture. does anyone have any opinion on my case?
i attached some pictures if any one can recognise what that is:
plug4 (1).jpg (7.51 KiB) Viewed 2099 times
after reading the another thread about high oil consumption i decided i will exchange my oil from 5w30 to castrol edge 0w40 like was recommended there not before i will do flushing to the engine and putting the oil on a clean engine with new oil filter.
I should say the car is with me for only a year. I bought the car in that situation.
what i did since i bought the car was:
replacing the plugs which started very fast to get this white build up again.
I replaced the pcv 2 weeks ago - a few month after the new plugs.
I renewed the catalytic converters to new ones (not original but by "Magna Flow"), after doing this i resolved the p0420 & p0430 for maybe a month and then it returned again 😭. Since then i am trying to find the root reason of all those problems - those codes, white build up and oil consumption. obviously something is causing this white build up on the plugs and probably it has to do with the oil and the converters.
I looked over the history of xc90 since the last owner.
he did nothing with engine beside replacing the drive-shaft. all the other stuff are maintenance - oils, filters and so on.
the only thing for our matter is that the problem of the p0430&420 started in 2017. from what i understand from the history and from what i recall him telling me, is that he didn't do anything about it.
here is summarized list of what i did since i bought the car:
1) replaced the the spark plugs to Denso 4704 IKH20TT Iridium TT Spark Plug
2) took out the catalytic converters and "transplanted" new convertres made by "magnaflow"
3) replaced to original pcv to vaico pcv
4) replaced the Lambda sensor to Denso DOX-0526
5) flushed the engine
6) replaced the oil to new Castrol EDGE Euro 0W-40 A3/B4 Advanced Full Synthetic Motor Oil.
7) added Restore 8-Cylinder Formula Engine Restorer and Lub
that's all that was done as i know. maybe something was done before 2017 or in a different garage that i dont know of.
since i did the oil change the car still gives the message about the engine but there is no check engine light right now. when i connect my generic computer it gives me the p0430&420 codes.
the car "eats" oil more than it should although its less than it used to be since the oil exchange to castrol 0w40 was done.
of course there is this white stuff on the plugs
and for the information all of the mechanics i talked to except one told me it is probably the Piston ring. the only mechanic who told me it is not is a Volvo pro who told me its because i didn't use original converters when i changed them. he says if there was a real problem with the piston rings i would have seen smoke coming out at least at the morning startup and there is nothing! it's totally clean.
that volvo mechanic told me that white stuff is normal.
about the pcv, i checked there is good vacuum by placing a rubber glove on the oil opening and checking to see it is sucked inside as many suggested to check.
looking for help on this
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
If you know the oil consumption is high and the weather is warm at this time, use Rotella T6 15W40 as 0W40 is too thin for your problem. The Rotella will clean and provide a thicker film so less blowby. You also need to clean the CATS. If you aren't already start using Premium fuel.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Cataclean, not sure I’m brave enough to try Scotty’s idea. Then 10w40/15w40 in summer and 5w40 in winter depending on temperature.
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Post by MoVolvos »
Krons wrote: 04 Apr 2024, 05:01 Cataclean, not sure I’m brave enough to try Scotty’s idea. Then 10w40/15w40 in summer and 5w40 in winter depending on temperature.
I remember Robert chiming in on his or another's success using this. I know for sure someone in CA posted success using the lacquer thinner.
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Here is the referenced thread since it may help to try to understand the information for this 3.2 (non-turbo) engine.
https://www.swedespeed.com/threads/p042 ... ion.675321
Good luck with the diagnosis.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
chitownV
Post by chitownV »
BTW, here is another thread from MVS forum about using a non-OE PCV and he continued to have issues. Getting a clear history of the work and the specific parts was also important. It may help to read it over for the process of trying to diagnose.
viewtopic.php?t=102615
EgoziAlon
Post by EgoziAlon »
From looking on information on plugs with white build-up it looks it's either a too hot combustion or too lean mixture. I did see a recommendation to replace the thermostat at this stage of KM -200,000 km.
I need help on what other parts can be checked to get better idea
EgoziAlon
Post by EgoziAlon »
Anyone?
MoVolvos
Post by MoVolvos »
EgoziAlon wrote: 09 Apr 2024, 12:00Anyone?
Plugs are quick and easy. Change to a good 10~15W40 oil depending on your climate and check plugs again on the next oil change. No more than 6 months or 5K miles whichever is first.
Use the lacquer thinner method after you do the plugs and oil change. Do the simple stuff first!
EgoziAlon
Post by EgoziAlon »
Can you explain me the difference between 0w40 to 15w40?
