1983 240 WAGON WONT START RAN FINE THE NIGHT BEFORE
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
steven bradley
Post by steven bradley »
WELL THE CAR RAN FINE ALL DAY. PARKED IT OVERNIGHT AND THE CAR WILL JUST TURN OVER. I DID PUT GAS IN IT THE NIGHT I PARKED THE CAR.IF YOU HAVE AND THING TO OFFER TO HELP PLEASE REPOND TO THIS POST THANK YOU.
markvt
Post by markvt »
When you say "just turn over" do you mena that it turns over slowly? If so, I would definitley check the battery. My practive has been when a battery is 5 yrs. old I replace it no matter how good it seems to be.
1992 240 GL
1966 Sunbeam Tiger
markvt
Post by markvt »
Oops, forgot to mention...if it turns over as normal and won't start, I would check the fuses for the fuel pump. They may not be burned out, but corrosion that you can't see will cause a bad contact. I had to get towed twice and it was bad contact on fuel pump fuse both times.
Check your fuse chart and pull out the fuse for the fuel pump. If it seems okay, pull it out and clean the ends of the fuse and the fuse contacts...you can use a pencil eraser or elect. contact cleaner. Put the fuse back and see what happens.
1992 240 GL
1966 Sunbeam Tiger
adrianpike
Post by adrianpike »
Check for fuel, check for spark.
Pull the plugs, smell for fuel.
An inductive timing light makes checking for spark a breeze, you might want to invest in one if you don't have one already.
Any pops? Any sputters? Any noises?
-Adrian Pike, Adrian Technologies
'78 16 Valve 245DL
