New member here but have owned an '02 2.4T for 10 years and just added an '01 T5. I've searched here and other sites but cannot find out definitively whether my cars have mechanical or hydraulic valve lifters/tappets/buckets. Both engines have the valve adjustment screws/ports in the cam cover and I've found the procedure for checking the clearance. But found nothing on knowing which style lifter my cars would have or how frequently they should be checked. Both my cars are high mileage; ~270K miles and from knowing something of their history, they are unlikely to have ever been checked.
I do my own maintenance and am familiar with DOHC solid valve systems having been an Alfa owner for 60+ years.
Thanks, Jim
How to know if my '01 and '02 V70s have mechanical or hydraulic lifters?
- Has thanked: 2205 times
Good question. I don't know if Volvo used hydraulic lifters after 1998- on the 5 cylinder engines. I am probably wrong, but looking at parts sited I think they all look like buckets not hydraulic lifters. Again not sure why there are about 30 options but I am going to think that perhaps it is to vary the thickness of the bucket so they are like shims.
https://www.volvocarstorontoparts.ca/a/ ... 89539.html
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
2000 was a running upgrade to that family of engines. Solid tappets and single point oil supply to a drilled passage for inside crankcase piston spray jets were the noted changes. The solid tappet does not use a shim but the whole tappet is changed for adjustment as the shaft that is on under side of tappet is ground to incremental thicknesses. The solid (mechanical) tappets effectively never need a check or adjustment. The 4 valve arrangement uses smaller and lighter valves and good materials for seats and valve faces effectively do not wear nor stress cam enough for it to wear. Adjustments are only needed when head is repaired. The 2000 engines had screw in plugs for clearance check but that was eliminated with maybe a few 2001s having the plugs before those were used up.
jrschwit
- Year and Model: '01 V70 T5, '02 V70
- Has thanked: 12 times
- Been thanked: 8 times
Thanks for both replies. I'll check clearances in both engines simply for peace of mind when I get the opportunity. I read elsewhere that '03 and later had the adjustment plugs eliminated from which I assumed they went to some sort of hydraulic tappet adjustment which obviated the need for checking valve clearance. But I understand that lighter valve components and better wear characteristics could also obviate the need for checking clearance after initial build/rebuild.
Jim
Jim
- Been thanked: 4071 times
Thanks jimmy! Hope you are well
I’ve got a the rare 2000 head with the adjusting ports in stock here, scavenged from Jane Bond
The break from hydraulic to mechanical lifters was mid 1999. I think all four of my 99s are hydraulic. Exact engine number is in the “ Bastards” thread
jimmy57
My post might be confusing in the "running upgrade" part. The engine had those updates in the middle of its life, not a running change during 2000 model year.
- 30 Replies
- 7782 Views
Last post by jkaspar
- 2037 Views
Last post by jimmy57
- 5133 Views
Last post by rspi
- 14 Replies
- 7763 Views
Last post by RickHaleParker
- 209 Views
