B5254T in 94 T5?
Clemens
Has thanked: 473 times
Been thanked: 219 times
B5254T in 94 T5?
Post by Clemens »
Because I just stumbled across a used B5254T out of a wrecked 97 V70 AWD:
Would this fit into my 94? The B5254T only has 193hp and a 13g. Could I just swap my 15G and Motronic related sensors over onto the block?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Clemens
Post by Clemens »
Well, according to this post it should work:
viewtopic.php?t=57106
Summer: 1996 855 R
Donor: 1995 854 10V
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
People have been swapping 15g/16T with T5 ECU and injectors on B5254T cars for a while, so I dont really see why it wouldnt work if you ran one with 15G and a T5 M4.3 ECU.
The engine itself is identical to a B5234T from the outside, every sensor should swap fine.
If you're not chasing power goals (where the 2.5 weaknesses are showing), it might even actually perform a bit better due to the extra compression
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
