White and brown goo on dip stick 1996 850 non turbo 125,000
alba93
Post by alba93 »
I've been seeing white and brown stuff on my oil dip stick. I know this can be an indication of a leaking head gasket. But I am also wondering if this could be soley due to condensation. I don't see anything unusal around the oil fill port. I do a lot of short trips, such as 3 miles then the engine is off for 30-40 minutes before another short trip. I rarley drive more than 10 miles without a period of cool down. I have needed to replace about 10oz of coolent recently. No other symptoms that I can see. Anyone know what I should expect to pay to have the headgasket replaced if it come to that?
Thanks!!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Your short trips will certainly lead to a build-up of condensation and it would show on the dip stick and, possibly, the inside of the oil filler cap.
Over what period of time did you lose the 10oz of coolant?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
alba93
Post by alba93 »
billofdurham wrote:Your short trips will certainly lead to a build-up of condensation and it would show on the dip stick and, possibly, the inside of the oil filler cap.
Bill.
I added the 10oz of coolant at one time. My low coolant light came on. That was the first time I added coolant in at least a year, maybe longer. This happened a day after the car was inspected. I tried to determine if the inspection repairs would have necessitated removing any related coolant hoses, they replaced both front brake hoses and the Neutral safety switch. I don't believe any coolant hoses would have been removed for these repairs?
The 10 oz of coolant was added about 35 days ago. None needed since then.
Aside from my general concern about the head gasket, the goo makes it almost impossible to make an accurate oil level check.
Thanks for your response!!
bugeye58
Year and Model: 740 turbo wagon, 198
Post by bugeye58 »
At what interval are you changing the oil? Short trips are hard on oil, as condensation never has a chance to boil off.
I'd do an oil change and continue to closely monitor things.
Jeff
'89 740 Turbo Wagon
'95 850 GLT
alba93
Post by alba93 »
bugeye58 wrote:At what interval are you changing the oil? Short trips are hard on oil, as condensation never has a chance to boil off.
Jeff
I change the oil every 3000-4000. Should I be changing it more often? I drive about 10,000 miles per year.
Thanks!
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Your oil change interval is fine...try to stick near 3K.
On the other hand, at least once a week, get the car out and really get it up to speed (and heat) on the highway for 30 mins at a time if possible. This should clear out your "milk shake" on your dipstick.
alba93
Post by alba93 »
MadeInJapan wrote:Your oil change interval is fine...try to stick near 3K.
Ok, thank for the advice!
bugeye58
Post by bugeye58 »
Isn't it wonderful when a nice drive can be considered preventative maintenance. :lol:
Jeff
'89 740 Turbo Wagon
'95 850 GLT
Svenska 850 Wagon
Post by Svenska 850 Wagon »
This is the 1st car I have owned that shows this little wht goop on the end of the stick. More common in winter. It is after my wife drives 3mins to the store :o
1995 Volvo 855 GLE 262,000Kms
1992 Subaru SVX 82,000 Miles
1981 FIAT Spider 194,000Kms
1981 VW Westfalia 164,000Miles
bobsnow100
Post by bobsnow100 »
Yea, I agree that it is probably just condensation and your not driving the car enough to evaporate it out of the engine. Another big problem from not driving it enough is that your exhaust system can rust out from the inside out as water also will condensate in there too and it is very corrosive to the exhaust system
Who is online
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Baidu [Spider], Bing [Bot], Google [Bot], MarinerMan, Semrush [Bot] and 13 guests
