Pulling a passenger front axle, 2004 S60
Oro
Year and Model: V70 XC, XC70+S60 awd
Has thanked: 7 times
Been thanked: 37 times
Post by Oro »
Tomorrow morning I need to pull the front passenger axle on my step-son’s 2004 S60, to re-boot the inner joint.
I’ve searched endlessly and other than 1/2 hour you tube videos in Croatian, not found a clean how-to. I’ve done this job MANY times on other vehicles, just wondering if anything is odd here. I can work though on my own, but if someone has a quick bullet-point check list of anything odd, it would be appreciated.
I saw something about inner soup cans being staked to prevent the tri-lobe coming out. A thing?
Thanks in advance.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
How many miles km in your car?
Use only GKN brand or Volvo brand.
I wrote a detailed DIY here:
DIY: 2004 V70 2.5T Axle and Seal (110K miles) Volvo 6843112; Corteco 19033885B R side: Volvo 9495018; Corteco 19034067B
viewtopic.php?t=91594
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Very easy. I undo the 2 giant bolts connecting the knuckle to the strut assembly, remove the 2 bolts holding the carrier bearing to the axle, then pull out. Have a replacement seal ready. You can also do it by popping the balljoint out but I prefer the above method.
04s60 2.4
04xc70 2.5t
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
What br0dy519 said; check out cn90's write-ups for great summaries and hands-on implementation of what's been posted across the internet.
Nothing special here, no soup cans whatever those are, just (as you said) don't over-stress the inner CV when you pull.
Has thanked: 1609 times
Been thanked: 4065 times
Have the inner trans seal in hand as well as a new outer dust seal between axle hub and driveshaft outboard to keep those splines clean since you are in salty ON
