Pressure wash the valve cover?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
beewstew
Year and Model: 2004 xc70
Has thanked: 32 times
Been thanked: 4 times
Post by beewstew »
Working on a head gasket repair. 2004 xc70, about 130k miles. I'm really surprised by the amount of coke (hardened oil) on the inside of the valve cover.
Assuming I manage to break the head bolts loose (cracked one 14mm socket in half so far) I'm not planning to take the head to a machine shop for refinishing. Is there any value or danger in running a pressure washer over the inside of the valve cover or the outside surfaces of the head?
https://github.com/ntmoore/2004_Volvo_x ... 146140.jpg
https://github.com/ntmoore/2004_Volvo_x ... 142706.jpg
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
I'm no help on the pressure washer, I get both of those parts cleaned at the machine shop.
But on the socket, are you using an impact grade socket? Even the cheap ones (e.g. Stanley) have worked fine for me. Sometimes you need thin-wall to fit in the recess and reach the head bolts, and a quality impact socket is too thick too do that. But a more cheaply made impact socket will be small enough diameter yet beefier than a non-impact, even from a better quality brand.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
The power washer will not be effective but may trap moisture in the grease not removed. Best to have a shop take care of it.
beewstew
Post by beewstew »
The impact socket that failed was a 20yo Harbor Freight 14mm. A new socket from the store and a 30" breaker bar did the trick.
I'm not sure I understand how/where the head gasket failed. Here's a few pictures of the gasket and related surface. No obvious failure marks like the Sabb 900 hg I did 20 years ago.
https://github.com/ntmoore/2004_Volvo_x ... 706042.jpg
https://github.com/ntmoore/2004_Volvo_x ... 649721.jpg
https://github.com/ntmoore/2004_Volvo_x ... 643466.jpg
https://github.com/ntmoore/2004_Volvo_x ... 252931.jpg
https://github.com/ntmoore/2004_Volvo_x ... 206854.jpg
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
erikv11 wrote: 29 Sep 2024, 14:02 I'm no help on the pressure washer, I get both of those parts cleaned at the machine shop.
You can get a quality thin-walled impact socket, too. Impact is must, though.
vtl
Post by vtl »
I would refrain from using a high PSI pressure washer, like 3000. 1700 PSI didn't do any damage. But it won't do any good without hot tanking.
Weld your own hot tank! I got 4 or 5 pieces of 2"x1" zinc plated steel sheets from Home Depot and stick welded a tank. MIG would be much easier. Also don't breathe fumes, zinc plated steel is not for welding and highly toxic.
MSR camping stove heats it up to 160-170 F, compressed air agitates the Simple Green + water solution. Take it out from time to time, let it air cool a bit, power wash what you can, put it back. When satisfied with the result, rinse with water well and spray with non-aerozol WD-40 or PB Blaster to prevent oxidation. I managed to clean all the parts very well and for cheap.
