Hi, having issues with front O2 sensor readings. Its 1999 V70 b5254S engine with Denso managament.
Replaced O2 sensor (denso), did not help. Measured volts at sensor heater pins, they get voltage. Post cat sensor reads around 0.7-0.8V. Short fuel trim and front O2 reading always at 1.00, no movement at all.
What else there is to check, readings should fluctuate from 0 to 1 volts constantly?
Pre cat O2 sensor reading always 1.00. Topic is solved
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
What are you using to read the sensor? When I look at O2 data, I graph it over time so I can see the change. I use the 850OBD2 app.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Markus123
- Year and Model: 1999 2.5 TDI
- Has thanked: 2 times
- Been thanked: 3 times
Its chinese clone of Vida Dice.454cid wrote: 28 Oct 2024, 08:54 What are you using to read the sensor? When I look at O2 data, I graph it over time so I can see the change. I use the 850OBD2 app.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
This is fine.
Anyway, 1.00 is not VOLTS, it's Lambda, the stoichometric fuel ratio, stoich is good. Anything above lambda 1.00 is considered LEAN. Anything below 1.00(such as 0.98) is considered rich, for a wide-band oxygen sensor.
All fuels require lambda 1.0 except in high RPM where liquid fuels help with cooling of the combustion chamber, giving a small knock protection. In all other instances, you want Lambda 1.0 for full combustion of the fuel mixture. Gaseous fuels such as LPG and CNG do not have this benefit and will instead choke an engine as they displace air and also contribute to higher heat.
Btw, Lambda is NOT air-to-fuel ratio which is 14.7(Lambda 1.0) for gasoline, 17.2(for CNG) etc.
Narrow-band oxygen sensors like the POST-cat sensor oscillate between rich and lean in a sine wave I believe.
When pressing the brakes from a high speed(as well as completely removing foot off accelerator in high speeds), your lambda should read 1.28(fuel cut off) and around 4500 rpm and above should be slightly rich around 0.95.
Markus123
Thanks for reply! Yep my bad, its lambda reading. Its strange as both pre cat and post cat sensors are 4 wired sensors, look idendical, so they must be narrow band? The current reading on front sensor -96.07 mA is strange also.
dikidera
They are nor equal.
The first oxygen sensor pre cat measures the exact air to fuel ratio so it can be 0.95 or 0.96 or 1.03 etc the exact, it's a wide band sensor. Post cat is a regular sensor measuring either rich or lean, it should be narrow band.
Additionally each of these sensors uses a reference air leeching via the insulation to produce the correct measurement which is why a pinched shroud or oily connector can cause a sensor to produce erroneous values. It's specifically mentioned in VIDA.
My information is for the later Denso 2.4 engines, but I am fairly certain it should still apply to you.
- 1143 Views
Last post by Talviomena
- 3353 Views
Last post by mrbrian200
- 19 Replies
- 8847 Views
- 1585 Views
Last post by Build
- 1279 Views
Last post by ellymayg
