Hi there! I just purchased a 2012 c70 and loving it! However, it has been giving me a message sometimes saying it is too hot or too cold to operate the top. This was troubling yesterday as it was down and I do not live in a place where I can just wait for it to change it's mind and let me put it back up. It seems pretty random when it will throw this message. Sometimes it does, sometimes it doesn't. Sometimes it promptly goes away when I try again, sometimes I have to come back after a few minutes and it will allow me to put it back up or down. I try hitting the reset info button. Sometimes that works, sometimes it doesn't. Also, I do not believe it is actually too hot or too cold haha. It's fall here and still t shirt weather during the day. Any advice on what to do about this? There are not many people in my area that will look at these convertible tops.
Thanks!
Too hot/cold operate top 2012 C70
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Info screen:
"It's really really hot out - ae you SURE you want to put the top down?"
precopster
- Year and Model: Lots
- Been thanked: 128 times
Signs of failing hydraulic rams. I've never seen a fix or anyone taking one apart to repair it. There are several of them fitted and super expensive. The trick is to work out which one is causing the issue.
In Activations with Vida you may be able to drive certain sections individually; worth a try.
ClydeOberbrunner
- Year and Model: 2020 XC90
I also encountered the same error as you, but I handled it your way but it still didn't work. Can you give me another way? Please help me!precopster wrote: 05 Nov 2024, 14:01 Signs of failing hydraulic rams. I've never seen a fix or anyone taking one apart to repair it. There are several of them fitted and super expensive. The trick is to work out which one is causing the issue.
mmpeterson1850
- Year and Model: C70 2012
Damn! I thought it might be the sensor since I have seen some posts about that. How did you come to that conclusion out of curiosity?precopster wrote: 05 Nov 2024, 14:01 Signs of failing hydraulic rams. I've never seen a fix or anyone taking one apart to repair it. There are several of them fitted and super expensive. The trick is to work out which one is causing the issue.
- 20 Replies
- 636 Views
Last post by cn90
- 17 Replies
- 4296 Views
Last post by villagepc
- 1531 Views
Last post by mod64
- 12 Replies
- 3117 Views
Last post by Kulu
- 1924 Views
Last post by mrbrian200
