Clean or replace oil trap?
beewstew
Year and Model: 2004 xc70
Has thanked: 34 times
Been thanked: 5 times
Post by beewstew »
Is the oil trap below the intake manifold cleanable? The oil was free from coke/grit/charcoal when I drained the engine post head gasket replacement and the oil filter passages were clear, but there were a few coke deposits in the inner small grooves of the valve cover.
Wondering if I should bother pulling and cleaning or replacing the oil trap before putting the intake manifold back on.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
If I had the intake off, I would remove and inspect the oil trap box. It can be cleaned, but you can't open it, so it is flush cleaning mostly. If nasty, I would buy a new one.
If you have the intake off are you doing the full PVC cleaning/replace?
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
If your car in a turbo then your can probably clean out the oil trap with carb cleaner or the like. However if your car is a non-turbo then there will be a vacuum control diaphragm that is integral to the oil trap. Those diaphragms get coked up to the point of failure making the oil trap a throw-away item.
beewstew
Post by beewstew »
@volvolugnut appreciate the info on cleaning - I'll probably try it along these lines https://charm.li/Volvo/2004/XC70%20L5-2 ... %20Repair/
Re "full PVC cleaning/replace" I don't know what this is. I'm operating on a "while everything is apart" impulse - nothing more sophisticated. Are you talking about this procedure? https://charm.li/Volvo/2004/XC70%20L5-2 ... %20Repair/
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If you have a lot of money, replace it.
Otherwise, re-use it after cleaning with gasoline +/- carb cleaner as mentioned above. It is just a simple plastic box.
Some years ago, I cut open the PCV trap (PN 1271988) in my 1998 S70, you can see the inside anatomy in this thread below. The design of P2 and P3 oil trap is almost identical...
viewtopic.php?t=55470
beewstew wrote: 01 Dec 2024, 20:49 @volvolugnut appreciate the info on cleaning - I'll probably try it along these lines https://charm.li/Volvo/2004/XC70%20L5-2 ... %20Repair/
This thread talks about the full PCV service I mentioned. Sorry I stated PVC instead of PCV. This is the Positive Crankshaft Ventilation system.
viewtopic.php?p=579887&hilit=pcv+service+clean#p579887
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
volvolugnut wrote: 02 Dec 2024, 11:31 Sorry I stated PVC instead of PCV.
Always keep your PVC pipes clean! Especially under the sink!
Just had a DA moment. Sigh.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
chrism wrote: 01 Dec 2024, 20:46 If your car in a turbo then your can probably clean out the oil trap with carb cleaner or the like. However if your car is a non-turbo then there will be a vacuum control diaphragm that is integral to the oil trap. Those diaphragms get coked up to the point of failure making the oil trap a throw-away item.
As per this older thread, the box itself is hollow, what chrism refers to is a diaphragm that sits on top of the box: viewtopic.php?t=99781
Here is chrism's pic of it for an 03 NA:
