DMM defroster 2009 d5
Garrigou
Year and Model: 2009 xc90 d5
Has thanked: 1 time
Post by Garrigou »
Hello chaps, I've googled the hell out of this problem but not found much information.
Recently bought D5 that's throwing a Damper Motor Defroster - no communication (DD33) code and a lower switch - faulty ID.
Lots of noise but very little air flow from the windscreen vents. Aircon works, other vents are weak but blow hot enough.
Only switch issue I have noticed is that when the heated rear windscreen is engaged, I get interference on the FM radio. :?
If I even knew how to access the Damper Motor in question that would be a start. I'm assuming it's a dash out job?
I don't have VIDA by the way, just an Icarsoft code reader.
Any help much appreciated.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Maybe something in here, last post has a link to another thread: viewtopic.php?t=99349
Possible some LIN bus corruption, this vehicle have heated seats? Might be something to consider- https://www.swedespeed.com/threads/hot- ... sa.593601/
Garrigou
Has thanked: 1 time
Post by Garrigou »
Thanks, ggleavitt. That helps. I don't have electric seats. I might see if I can get hold of a copy of the workshop manual to access that DDM!
