We had an accident (hit a deer on highway) out of town. A local mechanic removed the AC condenser and replaced the radiator so that we could drive back home. The AC condenser was not put back because the impact bar was bent and no enough place for the condenser. I've replaced the impact bar and got a new AC condenser. After checking online, I think there are three steps to replace the condenser.
Step 1. evacuate the system.
Step 2. put back the condenser.
Step 3. recharge the system. (I don't think I can do it myself. Will bring it to a mechanic shop.)
My questions are:
1. Since the condenser has been removed for about three weeks. Probabaly no need for step 1?
2. Since the condensor has been removed for a relatively long time (~ 3 weeks), do I need any special treatment for the system before/after putting back the condensor?
3. Should I worry about other parts of the AC? AC worked well before the accident and anything after the radiator looks untouched.
Thanks a lot!
Questions on replacing AC condenser for 2011 XC90 I32
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Hi rred,
I don't think you can evacuate the system if it's open. So you're right, you really can't do step 1.
Install the condenser. I would put in a new drier at the same time. The drier will pull moisture out of the air, and if the system has been open for a few weeks, it's probably saturated.
There's a capacity valve on the compressor that tends to stick as the unit ages. On mine, it doesn't provide cold air until the engine rpm's have been up for a bit. (I drive out of the neighborhood holding it in 2nd gear to get there faster.) I intend to replace mine the next time I have the AC system opened up, but I haven't needed to yet. You may want to include this in your scope.
Before recharging, I would pull a vacuum on it and leave it for many hours. (I do 12+ hours - overnight, at least.) This does two things - first, any moisture that's in there will boil off and can be subsequently removed by running the vacuum pump some more, and second, it checks for leaks. It should not lose any vacuum in 12 hours; if it does, it won't hold refrigerant, so find the leak and fix before charging.
I hope this helps!
Roger
I hope this helps!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 3666 Views
Last post by XCMat
- 1275 Views
Last post by SuperHerman
- 2332 Views
Last post by chitownV
- 620 Views
Last post by Matty Moo
- 754 Views
