'98 V70 No compression
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
I've just been offered a '98 V70 with no compression in one cylinder, and I am crazy enough to be thinking about it. Aside from a hole in the piston, which I assume would be creating compression inside the block, and easily checked. Is there any common valve problem that would create that situation. He has disconnected the fuel injector for that cylinder and is using the car. If it involves removing the head, I'm not too interested.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Has thanked: 1506 times
Been thanked: 3820 times
It is a head removal job. On these cars, 99% of the time its called a 'burned valve' which is an expression for a chunk of valve has gone missing, so no compression in that cylinder. You could borescope the top if a piston easily, a valve is harder but doable.
Has thanked: 1853 times
Been thanked: 1712 times
You can buy a cheap attachment these days for your cell phone. Buy a cable with the side mirror view that allows you to look up to the valves. I agree with Abscate this, or a less likely holed piston is the issue. Only way to be sure is head removal.
Has thanked: 293 times
Been thanked: 765 times
Post by erikv11 »
99% it's a burnt valve, which to be clear is easier to fix than a bad piston. But still a hassle.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Faust
Post by Faust »
Thanks you guys. I am familiar with all of the issues you guys mention, but I was hoping perhaps for a valve train issue I was unaware of. Too much money, effort, for a '98.
2004 V70
Post by erikv11 »
Oh and I did have one engine with a zero compression cylinder due to a broken valve spring, in a 98 S70 NA. But that's not very common.
'06 S60 R, 197k
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Faust wrote: 07 Jan 2025, 11:13 Thanks you guys. I am familiar with all of the issues you guys mention, but I was hoping perhaps for a valve train issue I was unaware of. Too much money, effort, for a '98.
Sometimes free is too much for a car. Seems more common these days than ever.
08 C702.5T (sold)
The non-Swedes:
Krons wrote: 10 Jan 2025, 04:31
A free Volvo can easily need $2500 of stuff to get it road worthy. True of any brand, really. It’s a common fallacy of owner logic to balance repair cost against “ what I paid for the car” or “ what the car is worth”. That’s strictly a flipper mentality.
