More than P0455 issue?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Surfmullet
Year and Model: 2001 Volvo S60 2.4T
Post by Surfmullet »
My 2001 S60 2.4T is throwing a P0455 code. I have replaced my evap canister, all of the sensors including the one directly upstream the evap canister, the MAF, and all the upstream and downstream lines. I even replaced both fuel rubber lines that goes into the fuel tank. I have no smell of gas when I’m driving so I doubt that it’s the fuel sensor seals. I have even bought a new fuel cap but I’m suspecting it’s still the fuel cap area issue because my service light throws a “”Fuel Cap is open or loose” and then turns off after I reset the check engine light with my BlueDriver scan tool. Any suggestions as to how to get a better seal at the fuel neck? Or in general, anything else that I missed?
If I get a DICE and VIDA, can I change something in the Computer to make sure that this isn’t an issue anymore? I’m pretty sure there is nothing wrong with my smog system anymore but I’m at my wits end on this hobby car.
Any help would be appreciated.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
I think I would smoke test it.
DIY smokers on youtube.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 17 times
Been thanked: 33 times
Post by ignatz »
I bought a couple of new gas caps recently and also got " Fuel cap is loose or open". These newer caps have a larger rubber gasket that get twisted out of shape if over tightened. My older caps clicked when tightened. The newer caps work fine if they are just snugged down.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Surfmullet
Thanks for responses, gents.
Mr. jonesg- Thanks for the DIY smoke suggestion. It doesn’t hurt to double check to see that my work is done correctly.
Mr. ignatz - Thanks for that knowledge. I’ll check my o-rings and make sure that I don’t overtighten. I did notice that it was twisted the last time I put gas in the tank.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Have you inspected the condition of the cover for the fuel pump assembly under the rear seats?
04s60 2.4
04xc70 2.5t
