Doing brakes on a 2004 xc70. Bought replacement rear calipers (left and right) from local reputable auto parts store. Boxes had different part numbers, but the reman calipers in the box both had the embossed "LH" on the caliper.
Aside from the location of the bleed screw, is this a big deal? Initially I was annoyed, but now I'm wondering if waiting for the exchange is worth the time and hassle. The bolt spacing and function seems basically the same.
Are right/left rear brake calipers interchangeable?
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 66 times
- Been thanked: 92 times
If I remember correctly, the flex hose thread location is also wrong in addition to the bleed nipple and your brake hose won't be long enough.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- Has thanked: 2196 times
- Been thanked: 1850 times
No. Different part numbers and as mentioned above, the bleed screw would be at the bottom making bleeding hard, and the flexi-pipe won't likely reach.
See drawing and part description below:
https://www.volvocarstorontoparts.ca/a/ ... 23673.html
beewstew
- Year and Model: 2004 xc70
- Has thanked: 34 times
- Been thanked: 5 times
So far the best answer I've found is that: while a LH rear caliper will bolt up fine and the supply line will reach to the same place on the rear RH side, a bleed nipple on the bottom of the caliper will make it hard to bleed out air bubbles in the caliper vs having the nipple on top which the air bubbles can float up to..
- 22 Replies
- 3469 Views
- 395 Views
Last post by jonesg
- 388 Views
Last post by Grantkat
- 2258 Views
Last post by GazmorGuri75
- 16 Replies
- 5292 Views
Last post by kaneelschep
