Purchased 10/31/2017 - $4500 on Craigslist in Washington State
(Original purchase date was 4/1/2004 from Lawrence Volvo, Walnut Creek, CA)
2004 Volvo XC70 - Silver exterior, beige interior
2.5L 5-cyl Engine B5254T2
Vin# YV1SZ59HX41153824
Original Owner Maintenance done by Lawrence Volvo, Walnut Creek, CA
10/14/2004 @ 8020 - 7500 mile service
5/11/2005 @ 14227 - 15000 mile service
1/12/2006 @ 22069 - 22500 mile service
2/24/2006 @ 29851 - 30000 mile service
3/30/2007 @ 37640 - 37500 mile service
9/25/2007 @ 46477 - 45000 mile service
6/24/2008 @ 54832 - 52500 mile service
1/13/2009 @ 61288 - 60000 mile service
10/21/2009 @ 71174 - 67500 mile service
8/10/2010 @ 79016 - 75000 mile service
4/19/2011 @ 86837 - 82500 mile service
3/21/2012 @ 95272 - 97500 mile service (skipped 90000 mile service in the record book)
2nd Owner Maintenance
Oil and Filter changes done regularly along with other maintenance (verbal statement only)
12/18/2013 @ 119704 - Timing Belt change (sticker in the engine compartment)
3/13/2015 @ 134418 - Front end suspension replaced strut assy, bump stop bellows, strut mount spring (Larry's Independent Volvo)
My maintenance
11/11/2017 @ 157500 - Oil & filter change
5/7/2018 @ 160206 - Oil & filter change, Oil fill cap gasket
6/8/2018 @ 164400 - PCV system replacement, cleaned electronic throttle body, topped off front bevel gear fluid (Viking Auto Svc)
2/22/2019 @ 165913 - Oil & filter, Fuel Filter, ATF flush (Amsoil ATF JWS3309 - 10qts used), topped off front bevel gear (Viking Auto Svc)
10/21/2019 @ 171054 - New tires - Michelin Defender 215/65 R16 (Discount Tire)
1/30/2020 @ 172746 - Oil & filter change
11/25/2020 @ 179000 - Oil & filter change, New brake pads & rotors, brake fluid change
12/28/2021 @ 188504 - Oil & filter change, serpentine belt change, Oil fill cap gasket, Cabin & Engine Air filter change, Haldex AOC pump, filter, temp/pressure sensor, fluid change, new spark plugs, new Volvo battery, new gas cover hinge (All Vovo Repair Shop)
*** Moved to Alabama ***
8/30/2022 @ 196425 - Oil & filter change
3/3/2023 @ 198556 - Oil & filter change
5/25/2024 @ 202528 - Oil & filter change
11/2/2024 @ 204000 - Rear wheel hub bearing assy replaced on both sides
1/25/2025 @ 205388 - Oil & filter change
2/15/2025 @ 205800 - Engine Air filter change
3/25/2025 @ 206000 - Piston 1&3 misfire code, Cyl 1 and 3 Coil packs replaced (Bosch), Oil fill cap gasket change
4/12/2025 @ 206100 - Coolant flush & replace, Heater core inspection (original Volvo - no leaks or failure symptoms)
5/9/2025 @ 206406 - Cyl 2, 4, 5 Coil packs replaced (Bosch), Cabin air filter changed
5/31/2025 @ 206599 - Lower right side engine mount and transmission mount replaced - preventative as both were intact.
7/10/2025 @ 207015 - MAF sensor cleaned
8/17/2025 @ 207383 - Turbo BCS (boost control solenoid) replaced
2004 Volvo XC70 - North to South Wagon
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
