Why did I lose power?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
I was just driving on a empty country road and it was already night, and just Iike in those alien abduction movies, my car lost all electrical power, for a second, the entire car blacked out for a second and then power came back, though i had to stop and crank the car anew.
Before that, seconds before, the only precursor was that my headlights started to flicker.
This smells like CEM, or battery? S60 2005 face-lift, L-shaped CEM. Every once in a while I would hear a relay click behind the dashboard but no symptoms.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
Did the headlights go out?
if yes, then I say battery/circuit, if it was ignition i'd expect the lights would stay on.
dikidera
Post by dikidera »
I mean the entire car, the instrument cluster, headlights, radio, all power. Even the door modules as I heard them resetting,
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
CEM relays. In your model year they are soldered. Start with EWD, try to identify which relay are responsible for powering modules that went out.
You may also have a water damage in CEM.
dikidera
Post by dikidera »
Now that you mention water damage, I did have a water leak from the sunroof drains being clogged that moved towards the A pillar on the driver side, dripping around on the air vents. Twice. It may have just needed time to develop symptoms...maybe.
