Rough idle <800 rpm when hot - 07 C30 T5 auto Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Has thanked: 1850 times
Been thanked: 1710 times
The car that keeps giving!!
So after a lot of testing, wire repairs, all the grounds cleaned, the owner brought a brand new battery. I installed it and put it on trickle charge over night. On removing the charger it is registering 12.6V after sitting a few hours. Checked the alternator with the electrical system with minimal loading (heating off, radio off and DRL's only). Battery showed a 14.6V charging voltage which I consider normal.
I started the car and no warning lights, and car idled nicely. Took the car for a gentle 10km run around the neighborhood and then a couple of harder pulls on the highway to see if I could get any codes. Car ran fine, but has a whine. I'm guessing the turbo, but it could be the alternator possibly? I have read of that happening on P1's where the alternator seems to run hot.
On returning home, all seemed ok, until I started to back into the garage. Then the car started running a little lumpy, and the idle dropped a bit below 800 rpm. Rev'd the engine and it rev's well and cleanly, but then drops back to a low idle.
Can anyone suggest where to look?
Perhaps I should check the charging levels when the car is hot and see if maybe the alternator is going bad.
I changed the battery as the old one had been overheated following a mechanic leaving the main engine ground being left off. It is possible it has caused damage elsewhere?
Thanks,
I've linked this to another thread on the follow on from this thread:
viewtopic.php?t=106623
