Oil problem possibly solved 1996 850 T5
sntee
Post by sntee »
Up until recently I was getting through a hell of a lot of oil.
No major external leaks to speak of and no white smoke, so I was struggling to understand where it was going.
I've been using synthetic oil, usually the good stuff with viscosity ratings of 5w30 or better.
However, a couple of months back, I got sick and tired of pouring expensive fluid into a seemingly bottomless pit. So I bought a gallon of relatively cheap 10W40 and chucked that in.......
Now here's the thing..... usually I'd get through half a gallon in just over a month, but I checked this morning and it's still showing Full on the dipstick after 2 months without a top up!!!!
Has anyone else had a similar experience? Does it make any logical sense?
P.S. The new stuff is still synthetic.... just a lower grade and loads cheaper
1996 850 T5 Auto Estate 165k miles and counting...... (or should that be "and hoping" ;-) )
"If it ain't broke, don't fix it!
If it is broke......... keep goin till it falls apart"
pfeener
Been thanked: 2 times
Post by pfeener »
I learned long ago that different oils behave very differently. Years ago I had a 1967 MGB that I normally ran straight Mobil 30W non-detergent (it was a long long time ago). One oil change I decided to put in a High detergent Mobil 10/30W oil. As soon as I started it up, it started to smoke. I drove it around the block and there was so much oil going past the rings it was actually dripping out the connections in the exhaust system. I immediately changed the oil back to the straight 30W and after I drove it for a 100 miles or so and all the oil burned out of the exhaust, all was back to normal.
greasefingerss
Year and Model: 850 wagon 1994
Post by greasefingerss »
Hey I had a 74 MGB and a 73 Triumph TR6. I used 20w-50 in them. Now they were really fun cars to drive but troublesome as h_ll.
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
pfeener
Post by pfeener »
Yep fun to drive, but engineering out of the 1930's.
