Hi, I drive a Volvo XC90 2004 2.5t. I recently changed the cylinder head gasket. Few days after I noticed that
1. The car will struggle to start after I have driven for 25mins. Once it does start, it will jerk for like 20seconds with white heavy smoke coming out of the tail pipe. If I drive on 40mph for 5 mins the smoke will stop.
2. Had the car scanned and the only error code that came up is p0014
3. Anytime I parked the expansion tank goes empty and yet there is water on the dip stick
At this point I need all the help I can get before the mechanic turn this into a money making machine. Please any advise from the house will be appreciated especially from those with or has experienced same.
Thank you all
Jerking and smoking after warm start.
- Has thanked: 2854 times
- Been thanked: 1332 times
Welcome to MVS, Omoeki. White smoke is coolant getting into combustion. It can be caused by a few things, most notably ... head gasket.
p0014 points to timing.
https://www.matthewsvolvosite.com/?s=wh ... ke+exhaust
https://www.matthewsvolvosite.com/blown ... -symptoms/
viewtopic.php?t=19239
viewtopic.php?t=103608
Thanks @mathew1 I have read the article sent via the link. My case is quite different. There was never overheating I have replaced the gasket and all these was after the gasket change. Now I just park the car on the garage pending when I know what to do Mechanics around this part of the world will just keep eating your pockets. Though I intend to start one by one. First get the timing (p0014) resolved by resetting the timing. 2 then have the mechanic loose the engine and redo the gasket. My question is this: can all these affect the turbo?
- 2377 Views
- 1996 Views
Last post by mateqh
- 3515 Views
Last post by 93ForMe
- 1097 Views
Last post by oragex
- 13 Replies
- 5330 Views
Last post by Herb Goltz
