viewtopic.php?t=56005&start=40
Evita is a 25 year old s70 which my daughter daily drives. We got her in 2018 with a stuck engine, freed it up and she drove her for college, and now for her first two jobs. She is the only person in her office under 30 without a car payment, good for a $5000 after tax raise at work. She inherited my “ don’t do heat well “ genes and has been suffering no AC for two years. I decided this car deserves the attention given how well it has served us; college, then a 4x minute Long Island commute for two years, now a 5 minute commute
Wiki of job hours - trying to beat 10 hours all in.
Day one - two hours to get dash out
Day two 3 hour to get HVAC OUT AND evap replaced.
Day 3 1 hour to get all the bolts and old parts ready for install
Day 4 1 hour , install new Nissens heater core , install HVAC system into car. Broke the heater firewall interface, new one FCP $350
New one in stock, free
Day 5 2 hours for dryer, hard lines, suction line…..pumped down and system pegged vacuum gauge, held with no leaks for 4 hours, do no gross leaks.
Day 6 2 hours of electrical plugs, \dash hardware, and charging AC while doing same
Day 7 - I will need one more hour to sort out console and rest of fittings.
Achieved 40F delta with AC on ambient 84F day, at 2500rom, fan 3, RECIRC
GRAND TOTAL 12 hours, $150 in parts.
Forgot to remove the ECU cooling hose which was tight and hung up HVAC. On my other cars it would pop off easily
I forget to pop the climate filter gaiter off the cowl which hung up climate unit removal.
Her car has the nice amp so there’s a module in the way of the heater core T20 screw , three m8 13mm hex to remove
Job note..you need two sets of evap seal to fully seal the evaporator into the hvac. Part 9171783
Install the core, rubber gaiter, sliding door into the top of the hvac , then slide it into the unit and do the clips/t10 torx screws
You really need two people to remove dash. I fought it solo and that was stupid. Get help. It’s bulky, heavy, and fragile
Link to the master oring thread for part numbers for all those little orings in this job…
viewtopic.php?t=88579&hilit=Master+ac+oring
Scope of work. I’m replacing evap due to leak, found her heater core was seeping so will do that too.
