2002 V70 2.4t TCM-0094
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mechmike189
Year and Model: 2002 V70
Post by mechmike189 »
I have a 2002 V70 2.4t. It just over 90K and has been a great car for the past 70K miles we have owned it. Just today it set a TCM-0094 Gear Selector fault. The instrument cluster indicator operates as intended & the trans shifts perfectly but the code pops back up after being cleared. Scanner data indicates operation of the switch with movement through all gear positions but position indicator on the console does not light up.
Additional history, my warning triangle has been on for 2 years since Installed LED headlamps, which do out perform the halogens on my rural roads.
During the scan I found these other codes but again everything is working properly. None of these codes turn on any warning indicators CEM-6A02;Door lock signal high, CEM-8F21; Wipers signal high/missing, Uem-0004; Siren Communication fault, DDM-002B; Mirror motor MC signal low, DDM-0024; Mirror Motor MX+ low. ABS-0100: communication error with ECM. I have inspected for any rodent damage and the data through my scanner indicates that it TCM is registering shifter movement correctly.
I am thinking about cleaning ECM, TCM & ABS connectors as a start. Any recommendations would be great.
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 155 times
Been thanked: 141 times
Post by Vova585 »
I would try to find official data troubleshoot of this code. Possibly pay for alldata DIY for 1 month vs trying to dig up info in vida. It is possible that system is using redundant inputs. Gear selector for example reports to ecm, but it also has an input sensor inside transmission that shows what gear the car is. So possibly input from trabsmission is incorrect and thus car has code. It interprets as "active fault" so hopefully it will be easier to trace something that constantly present. Sorry unsure of specifics, but that os my guess.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
LED drivers emit a lot of interference into the power system, it is well known that replacing halogen bulbs with cheap LEDs can cause problems with electronics.
I would start with disconnecting the LEDs, clearing the codes yet again and checking if your problem is resolved.
