Aftermarket ECU for '97 850 T5 (Wagon)
Ok, so, to start off, I'm the third owner of this specific T5 -- second owner bought it off auction after first owner sold it off. I've had a problem with misfires for a couple months now, and didn't really pay too much mind to it, up until about a couple weeks ago. Check engine light popped on after a while, and the codes showed for a cylinder 3 misfire (earlier codes brought up cylinder 2 (2 codes), and then later on 1+3 (4 codes). Now, I can definitely feel the misfire, and it doesn't help that I have a mysterious oil leak (5 quarts lost in 2 months..). Anyways, I sent it in to a local shop that I trust to take a look at it and diagnose / fix it. They told me that I have an aftermarket ECU (I never knew about it), of which has no visual identifiers. They couldn't figure out what make / model / etc. of ECU it is, and also told me I'm getting a grand total of 103 codes. They said they didn't feel comfortable working on it, and redirected me towards a branch of ipd. The tech that I talked to on the phone told me that he didn't know of any aftermarket ECU's for my specific model. Are there genuinely any ECU's that it could be, or am I cooked, so to speak?
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
I'm going to guess that you have a ECU that was reprogrammed by a tuner at some point in the past.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2654 times
- Been thanked: 1247 times
Welcome to MVS, t5estate. Look around for a proper ECU. They're very easy to pop in and out. eBay would be where I'd try first.
- Has thanked: 292 times
- Been thanked: 765 times
What Matt said - get a generic t5 ECU for starters. May not match your emissions setup but sounds like those few codes will be minor.
1997 T5 was Motronic 4.4, the 1996 turbos were Motronic 4.3 so better to *not* get a 96 or earlier ECU.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Sveedy
I'd reach out to a tuner first before spending that kind of $$. Might just be a matter of reprogramming it, which would probably be less than $200.
https://www.vasttuning.com/
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1847 times
- Been thanked: 1710 times
I like they sell an AWD P80 fuel pump as a complete unit for a reasonable $300 US + shipping. Also an AWD downpipe although I'd need to see if it fits a 19T turbo on a 00 R.
Agreed, for sure don't buy a new $700+ ECU. I posted that link to show part numbers. I should have added a disclaimerSveedy wrote: ↑03 Oct 2025, 13:40 I'd reach out to a tuner first before spending that kind of $$. Might just be a matter of reprogramming it, which would probably be less than $200.
Looks like eBay has 850 ECUs for $50-150ish.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 334 times
Only the GLT(US) LPT was M4.4 in '97 (Well, for the turbo cars at least) . It however is NOT the same as the 98MY M4.4.
A '97 T5 is M4.3.
