Lowering the rear of 97 855 GLT
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
HareBall
Post by HareBall »
I want to lower the rear of my 855 to level it with the front. All the kits I see are for lowering both front and rear. I wouldn't mind lowering both if I could get the rear level with the front.
Anyone know where to get what I need? I don't haul any weight to amount to anything, so I am not worried about losing load capacity.
Larry
Li'l Red Wagon
97 855 GLT
csbrianp
Post by csbrianp »
I cut the rear springs on my 850 sedan before I cut the front springs just to get the same thing you are looking for. I cut about one and a half coils. I used a cutting disk that can be used in a 3/8 drill, that and a vise to hold the spring worked just fine.
Lowing the rear of the car will slightly reduce the weight transfer to the front under hard turning, making it turn better.
Brian
