Exhaust system volvo V70 xc 2000 p80
dzielnywojak
Year and Model: 2000 v70xc
Has thanked: 1 time
Post by dzielnywojak »
Hi i have volvo v70 cross country from year 2000 and I’m preparing to make a new exhaust because right now it’s just a straight pipe. I need to find out what diameter the pipe should be and a picture of how the exhaust should be routed.
Has thanked: 1613 times
Been thanked: 4078 times
It’s pretty complicated on an XC. Here is a picture from my s70 awd. Same exhaust
16 December 2020 entry in this thread
viewtopic.php?t=94605
dzielnywojak
Has thanked: 1 time
Thanks for answer. I will try to make something out of it
Has thanked: 2215 times
Been thanked: 1853 times
I have seen aftermarket systems out there, and some in Europe. Not sure if they are still available. You could consider an 'R' system as I believe they are made by some Euro manufacturers, just not Volvo. Try Sweden. If you can find an R one you will have to modify the rear bumper for the 2nd tail pipe. Some AWD cars' had a section to remove for this.
In North America there is a system from Viva Performance like that made from T304 stainless steel. Not cheap!
https://www.vivaperformance.com/exhaust ... f5wd45B4Vz
In Europe:
https://www.europeantuning.com/TME-Spor ... WD-1997-00
and:
https://simons.se/en/products/simons-sp ... wd/020-h8/
That looks like the same pictures Viva Performance are using.
At the bottom of the page there is AWD systems from Jetex:
https://www.carnoisseur.com/exhausts/ex ... e-selector
