Can anyone help with new ideas!
Car has B5254T2 motor, 2006 with turbo and 209 hp.
Its VVT sprocket area leaks oil. Oil can be seen coming behind the sprocket. I have replaced the axial seal between VVT-sprocket and the engine body - called front cam seal. I also have there a new VVT-sprocket having also a new green O-ring inside.
But no matter which depth I install the seal, I get oil leak from behind the VVT sprocket. I have Volvo tools +0, +1 mm and +2 mm, but no help.
The issue started when I installed the cylinder head after machinery works and replaced turbo.. (The cylinder 3 had issue which was caused by a loosen steel ball, which had got loose from a banjo bolt and entered into the intake manifold and from there into the nr 3 cylinder and finally through turbo to exhaust pipe.)
I have checked and learnt myself all about this issue, but no success to find the reason.
Today I started to think, if the cylinder head gasket is not correct and not suitable for this engine even...blocking oil flow.
V70 turbo year 2006 209 hp
Chili58
- Year and Model: 2003 XC70
- Has thanked: 3 times
- Been thanked: 12 times
Well - it was OK beforehand. Now I used a RTV silicon sealant outside the cam seal. Lets' see tomorrow when it will be dry, how it works.
Nice advices here: viewtopic.php?t=100439
- Has thanked: 2199 times
What brand of seals are you using? When I bought my 00 V70R it had supposedly had the engine seals done. Not long after buying it I had to pull the engine and replace all the crank and cam seals as they were leaking.
Since then, I only use Volvo or Corteco (OEM supplier) seals.
Is you seal fitted back to the same depth the original came out?
Chili58
Yeah, issue can be Victor Heinz seals, which I tried. Corteco could be more tight.
I tested different depth, but no difference. Used 3D printed, original design tools.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 66 times
- Been thanked: 93 times
Did you verify the PCV system is clear and the glove test passes? The slight vacuum inside the engine from the PCV system helps keep oil from leaking out the cam seals.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- 2781 Views
Last post by TheMrFailz
- 2050 Views
Last post by oragex
- 1050 Views
Last post by 850forum
- 7634 Views
- 983 Views
Last post by erikv11
