Smoke from dip stick Volvo 960 3.0 1997
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
AndreBKK
Post by AndreBKK »
I own a Volvo 960 in Thailand. Unfortunately the service is very bad and I don
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Three questions:
What is the mileage of the car?
Can you confirm there was no smoke from these points before the oil seals were changed?
Have you any documentation from the mechanic as to which oil seals he replaced?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
AndreBKK
Post by AndreBKK »
Thanks,
The Mileage is now 162,000Km.
I don
billofdurham
On that sort of mileage (or is it kilometreage?) the first thing I would suspect would be the Positive Crankcase Ventilation system (PCV). If it is choked, back pressure in the engine could cause oil to be forced out of seals, up the dipstick tube and around the oil filler. The PCV is often overlooked on car servicing but is an essential part of the car's emission controls.
This is Volvo's recommendation for the PCV for your car:
60,000 AND 100,000 MILES:
PCV - FLAME GUARD: INSPECT, CLEAN NIPPLE AND HOSES -
Maintains proper emission control.
Clogged flame guard may cause oil seepage.
If you are not mechanically minded it may be better to leave it to a mechanic. However, if you wish to try we shall give you guidance.
Bill.
Previously:
AndreBKK
Post by AndreBKK »
Thanks again! And it is
billofdurham
The PCV system is mounted on the left side of the engine under the intake manifold.
There is an oil trap with 2 pipes coming out of it, one from the top and one from the side. The pipe coming out of the top of the oil trap includes a flame trap which becomes clogged with oil over a period of time. It is this part, #12 in picture 1, that causes the problems. Some people try to wash this out with petrol or a proprietary cleaner but I think this is false economy as the part itself does not cost too much. If Volvo parts are hard to obtain in Thailand this could be used as a temporary measure.
Picture 2 shows where the flame trap is. The second shot on this picture will be what you see before it is dismantled.
Hope this helps.
Bill.
Previously:
AndreBKK
Post by AndreBKK »
Thanks for the instructions. I will replace/ clean the parts recommended and then post an update.
Andre
