Rough idle at times
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
torrec57
Rough idle at times
Post by torrec57 »
I'm problem a problem, not all the time, i could drive for an hour OK and then for a few seconds the engine shakes and then back to normal, it runs the worst after a gas tank fillup, i've replaced the oxygen sensors, the air mass sensor and power pack modules so far $$$$.
1996 964 178K miles
Duder
Post by Duder »
I had a similar problem and ended up replacing things that didn't help much. However I would recommend replacing the fuel pressure regulator, its easy to do and increased my fuel economy and improved the idle issue.
'86 Volvo 4cyl Turbo Wagon 760 Automatic
Static_Afterglow
Post by Static_Afterglow »
check the vacuum lines........
