Hi all.
I needed to replace a door check-strap recently, and couldn't find an on-line guide to removing the interior door panel, to provide access. This precipitated consulting that old-fashioned repository of knowledge, 'the book'. I had to find it first! Anyway, I built some 'how-to pictures' for those of you who lack 'the book', and are wondering how to get that door panel off to provide access to window winders, speakers, wiring, check straps etc.
Tools required:
* small flat-blade screwdriver
* Torx drivers or sockets: T20, T25, T30
* #1 phillips screwdriver
* long-nose pliers
Now you can get on with fixing whatever it was you needed to get to!
Hope that helps.
If you want to pin this or add to the 'repairs' list, please feel free. I hope some folks get some use out of it. The idiot who tried to prise the door-lever cups upward sure could have used this!
cheers
'olaf'.
PS - a big plug for picture hosting on www.flickr.com!
850 - interior door panel removal (in pictures)
850 door panel removal (pics)
850_olaf_nz
- Year and Model: 1997 855-T5
1997 855-T5, 182k km, as stock as a stock thing.
- Has thanked: 17 times
- Been thanked: 35 times
Great! Posted in the repair database!
Thanks for the info. I wish I had it last weekend when I lubed my sticky door mechanism on my '94 850 wagon. I just wanted to add a couple other tips:
-For the rear doors the long screw that mounts the speaker and holds on the door panel is the top left one.
-With the rears doors there was no need to remove the padded inserts as the top od the door panel is seated on brackets and lifts up and off once you've removed the fastening screws (at the bottom and on the speaker)
1994 850 wagon, 5 spd, 373,000mi
Thanks 850_olaf_nz,
I have had something rolling back and forth in the passenger door for a while now and was just going to live with it as it only rolls when turning sharply.
That is until I found this "how to...with pic's
" and I'm going to save to fave and find out what it is this weekend. It's been raining all week and all I have is the back yard to play in. Not good working in mud.
I'll post back with a pic of whatever it is rolling around in there.
Thanks again and GREAT JOB
Later
Later
"You Need Pride In Your Ride"
howie
- Year and Model:
Helpful post, the almost final tweak on my 850 GLT is to fix the door handle, you can't open the door from the outside with the window down since its hitting on something in the door.
2000 Volvo S70 SE, 145.000 on the clicker Gone
1998 V70R 195.000 Gone
2008 C70 86K
2008 C70 86K
Hi, I recently bought a 92' 850, but sadly the front passenger window is broke.
I suspect there's something wrong with the electric motor.
I want to check it out, so I need to open the door panel. I didn't know how until I found this great guide (thanks a lot).
But when I came to part/picture 4, I see that my panel lacks the two screws you have, and now I don't know what to do next.
I don't want to break something, so i hope you guys have some advise for me.
Here is a picture of my door-panel:
(Sorry for my bad English.)
- 921 Views
Last post by 8ball
- 585 Views
Last post by obayha
- 2683 Views
Last post by Mike Langlois
- 2594 Views
Last post by jonesg
- 1221 Views
Last post by halseyfolk
