MASS AIR SENSOR
turbo4door
- Year and Model:
I noticed my gas mileage was steadily declining. Stage 0 is done. I took off the MAS and noticed some dirt and corrision.. What type of solvent do i use to clean it, without destroying it?
turbo4door
- Year and Model:
so carb cleaner wont harm anything? i was looking at some electrical connection cleaner.. do u think it will work da same?
bobsnow100
- Year and Model:
PEP BOYS has a special spray cleaner for it that doesn't leave any residue. I've read not use carb cleaner on the wire
I did it a year ago and I sprayed it thouroughly, no problem since. It is not phosphoric acid, the wire is made of metal and this wire is heated at around 390 degrees while it is in operation. I wouldn't be afraid.
S70 GLT 2000 Moondust
turbo4door
- Year and Model:
i am gonna try it. wish me luck!
Turbo.......don't forget to unplug and clean the MAF plug contacts while your cleaning the MAF. Sometimes a low output from the MAF is caused partially by a dirty corroded plug.
Cheers,
Fred
Cheers,
Fred
1997 850
2007 S40
1998 E300 TD
1969 Austin Mini
2007 S40
1998 E300 TD
1969 Austin Mini
- 13 Replies
- 10435 Views
Last post by jimmy57
- 957 Views
Last post by tamtam2122
- 2483 Views
- 1220 Views
Last post by jasontindal
- 1180 Views
Last post by 93Regina
