Hello everyone,
I currently own a 1994 850 Turbo wagon and I'm planning on buying a roof rack to carry bicycles, etc. Does anyone here knows about the installation of this? Is it pretty straight forward? I've noticed that the molding on each side on the roof of the car peels off and looks really bad, I was thinking of replacing it all with a roof rack, its kind of an expensive fix but worth doing it if you like to travel and take your bicycle. Thanks.
Roof rack installation for a 850 wagon
Volvo Roof Rack Installation Notes
I just came inside from installing the Volvo load bars on my '98 S70 (Same part number for '94 850). Couldn't be easier...no tools, just a cam lock adjuster. They mount in the little holes in the upper edge of the door sill. I didn't want to spend the big money for a whole roof rail system, so I bought the load bars ($150 from boston volvo village) On those bars you can mount anything you can think of with adapters from Thule or Yakima. I just use it for a cargo bag and the occasional weed whacker or 2X4.
stone36
- Year and Model: 2005 V70R and XC90
You can also get used "euro rails" from ebay sometimes or from a parts yard. Ebay will cost you about $100-$150, I got mine from a parts yard for about $20 (lucky me). But will then need to buy the cross bars and bar attachments. I have found on ebay generic round bars and adapters for about $60. They key is to find a maker and cross reference what other makes and models the attachment will fit. For instance, the yakima lowrider, will fit the euro rails, but also say the VW passat. So serach on ebay for a rack that fits passat. This was just an example I don't know if the passat is the exact fit, but the ones I found were half the price of what were listed as a "volvo roof rack".
The install couldn't be easier for the rails. three torx screws into predrilled holes under that nasty molding. what you need to be carefull of if you just buy used rails is you need to keep the moulding from the hood up to the roof and cut it off with a hacksay so there is enough to go under the rail. It's just like a haircut, you can always take more off, but you can't put it back on so be careful.
Good luck
Good luck
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
CarVolvo
- Year and Model:
The actual rails on the wagon which go over the "rain gutter trim" that peels attaches with 3 screws which go into holes in all 850 wagons.
The cross bars attach to these. Both are easy to install. You will have to cut the "rain gutter" trim to fit the exposed part of the rails..about from where the sunrrof begins to the bottom of the winshield again.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
I'm headed to the parts yard today for rails, and cross bars if i'm doubly lucky, for my 94 850 wagon. Is the S70 the only other compatible model for roof rails? what about 760, 960?
Thanks
Thanks
1985 245_Manual Transmission_Tan
1994 855_Manual Transmission_Green
more info here on a question I posted. sorry about the double posting...newbie to forum life...
https://www.matthewsvolvosite.com/forums ... =1&t=40356
- 1164 Views
Last post by packetfire
- 8383 Views
- 2619 Views
Last post by 240fanatic
- 2475 Views
Last post by ande2
- 913 Views
Last post by rspi
