2001 s60 check engine light and weird idle noise
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
lukevolvo
Post by lukevolvo »
Recently got a check engine light, it has been intermittant past few days. Lean Bank one code. The car is surging at idle between 550 and 1000 RPM. There is also a loud squelling noise, almost a whine. Not a belt and no vacuum leaks. Any ideas on the noise? Going to try an o2 sensor for the check engine light. I 'll post how that goes. Love these cars, wife drove it 75K in under two years no problems with car until now, just a grumpy wife.
CarVolvo
Post by CarVolvo »
check the wifes check engine light...but cant help you with that..you have to know the model and what keeps her going :P
why not get a reading of the system before attemting anything?
does your system come with an air pump? Could the steering fluid pump, alternator or a/c compressor or one of the rollers be going?
When was the last time you had your timing belt checked?
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Most likely an 02 sensor but since Volvos sensors are expensive why not let a Volvo dealer pinpoint it?
Their computer will tell you exactly which one it is
lukevolvo
Post by lukevolvo »
The car has 100K miles on it. It is an S60 non-turbo. The check engine light was for lean fule mixture on bank 1 (OBD code po171). I recently had the timing belt and water pump replaced (unrelated preventative maintenance). Checked the oxygen sensor with a multimeter and both are working fine. I was wrong about the vacuum problem, no leaks but there was a clog. Vacuum problem is most likely in PCV system and it is casuing the noise. By loosing oill cap the noise goes away. This car does not have a PCV valve, but I was told it clogs. Took the lines apart found large carbon deposits clogging the bottom line. Cleaned it up and replaced short hoses. Car runs a ton better, idles better, but the noise is still there along with suction on the oil cap.
