Hi There
The fan for my climate control seems to have a life of its own. One minute it is working, the other its not. When its not working I am unable to turn the fan on manually.
Has anyone any ideas what the problem could be and how to fix it?
Thanks
Anthony
S60 2001 - Climate Control Fan
boncelondon
- Year and Model:
Hi you can try to clean the air temp sensor by vacuming it and then resetting car by removing battery negative lead for 6hr minimum..car will run rough at first but will re-learn in few hours...when you first put key in and switch car on turn fan to full for few seconds and then off repeat afew times..
hopefully this should sort issue
- 624 Views
- 1788 Views
Last post by alschnertz
