Door lock actuator for a 1998 volvo s70
skouf
Post by skouf »
I need to replace the front and back right side door lock actuators on my 98 volvo s70. How hard is it to remove the door panel and do I need any special tools? My next question, will any actuator work or do I need to replace them with oem?
Keep up the good work!
Skouf
cosmicdust
Post by cosmicdust »
Hi, my V70 (98) has the same issue, passenger side actuators. Any help would be apprciated!
1998 V70 AWD/GLT Turbo
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Not hard and no special tools needed.
Front door:
1. Remove the panel for the door mirror.
2. Gently prise off the surround for the interior handle.
3. Remove the cover for the interior handle.
4. Remove the screw for the interior handle.
5. Carefully loosen 7 clips in the bottom edge of the panel and slide the panel upwards.
6. Disconnect any electrical bits on the panel.
Rear door:
As above but omit step 1.
As for the actuator I don't know who else would sell them except a dealer. Somebody else may be able to help on this.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
There are no aftermarket actuators, when you see the part you'll know why.
Not a small part about 8-10"" squarish.
They cost about $140 from the dealer or you can call www.erievovo.com and buy a used one for about 55-65 bucks.
The door panel has to come off. Not the hardest of jobs but not the easiest either
