Fuel Pump Problem 1987 240
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
chriscruz2006
Post by chriscruz2006 »
I want to know if someone could tell me where I can find a relay for the fuel pumps, I check voltage coming on the fuel pump and it was 6.5 volts. Anyone that can help please
wojeepster
Post by wojeepster »
Passenger side footwell above passengers right foot. Peel back carpet and you will see large white relay. www.fpcgroton.com $20 I keep a new spare in my car......They are a known weak point on volvos. You say you have 6.5v at fuel pump. If that is on the ground side that means you have a bad ground. If it is on the power side it means you are losing 5.5v elsewhere in the circut. Do you know how to do voltage drop testing? You test each leg of circut You should have small drop (like.2v) over relays and switches and such and a 12v drop over the load device (in this case a fuel pump) Then you should also measure zero or a small voltage drop on the ground return......
