While intalling an amp in my 1999 C70 I moved the passenger seat all the way forward and when all was said and done the seat would no longer move. No sound comes from the seat however heat works. I checked all the fuses and wiring to make sure everything was still plugged in but didnt solve the problem.
I read that there is a shut off if there is something stuck on the track but I was unable to solve the problem.
Does anyone have any solutions?
Thank you
1999 C70 Power seat failure
- Has thanked: 2858 times
- Been thanked: 1332 times
It sounds like seatback cable. Sort of.
https://www.matthewsvolvosite.com/chat/p ... hp?t=11943
Yes, that's why it's kinda like it, but not really.
Unless someone replies, I think your best bet is to search this site and the other Volvo sites for similar symptoms. My memory bank of Volvo issues/fixes just doesn't offer up anything for this one, Keenan.
The power seats on coupes are unique in the way they work. When you tilt the seat back forward, the entire seat will move forward, and when you tilt the seat back to the normal position, the entire seat will move back. It does this with the help of two micro switches, one for the seat back lever, and one for the seat back position when it is tilted forward.
Your problem is with one of these switches.
B
B
Hi All...
My '99 C70 convert has "the" seat problem...seat back stuck forward. Springy things are intact. Per others I'm trying to inspect cables by pulling off leather but stymied by the seat back release lever.
I see the torx screw for the plate, but how do your remove the lever? Don't want to pull too hard for fear of breaking another part (ugh).
BTW is there anyway to just mechanically release the seat back? I really don't care if it works, just so long as it is not stuck forward.
Thanks!
Ralph
Thanks!
Ralph
- Has thanked: 17 times
- Been thanked: 35 times
Ralph,
Send me an email and I'll send you an pdf file that may be helpful to you regarding this procedure. badger36-at-knology.net (replace the -at- with @).
Regards,
MIJ
Regards,
MIJ
You emailed me so I'm posting what I was thinking about here...I would think something got unplugged:
adriennesvolvo
- Year and Model: 1999 c70 convertible
Got the pdf file, thanks for sending it. I'll try again after work and let you know how it works out..thanks
- 1851 Views
Last post by precopster
- 857 Views
Last post by cansavural29
- 920 Views
Last post by MoVolvos
- 1955 Views
Last post by SuperHerman
- 362 Views
Last post by amiral1982
