My cat is starting to smell pretty burnt up when I drive it for any period of time. It could be just moisture but I smell this heat smell a lot of times when I step out of the car after a four hour drive. Any ways, I wanted to know if it is alright to use an aftermarket cat on the T5, I herd it messes things up. I think it would free the turbo up though a bit. I already custom made from the cat back but didn't want to mess with the cat unless I had to.
Help!?!?
Thanks
Catalytic Converter, 98 Volvo s70 T5
fletch02536
- Year and Model:
- Has thanked: 17 times
- Been thanked: 35 times
A lot of people do.... Magnaflow if I recall. Do a search here...I think there's a write-up about it.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
The next time you drive your car, give the cat a visual. If it is red hot, it could be that something else is the problem.
Are you running rich? What's your MPG like?
Klaus
Klaus
Klaus
fletch02536
- Year and Model:
Actually the problem ended up being that the turbo oil return line was leaking out onto the cat causing a bad smell. I ordered some o rings online but I was sent the wrong ones so I made my own out of some rubber gasket material.
- 4412 Views
Last post by MadeInJapan
- 1857 Views
Last post by Ozark Lee
