ok ppl, I really need your help; I'll try to explain this as clear I can, english is not my first language.
car info: V70 - 98 gas, non turbo, automatic, 222.000km (canada)
I start in the morning, cold engine, start at half key, idle OK, absolutely no problem.
Drive 4, 5 minutes engine warm up to normal temperature the problem appear: variable idle 800-1100rpm, when in driving loose of power, acceleration poor, very rough running, not able to goes up to 2000rmp. With car stopped, with drive stick in run (stop at traffic light for example) the same thing, with drive stick in parking engine looks OK, idle constant, rpm responding fast , acceleration looks good. Sometimes the check engine light goes on, sometimes no. Most of the times came on.
All this problems during 10-15 min, if I run more than that all came back to normal.
After I stop the car, if engine still hot, all runing OK, if the engine back cold the same problem.
Only one code P0204 Injector Circuit Malfunction Cylinder 4
What I changed or verified:
distributor cap, distributions rotor, spark plugs and wires kits - changed new
RPM sensor checked - ok
camshaft sensor checked - ok
injector no 4 checked - ok
ignition coil checked - ok
all this I actually replaced them with used parts, absolutely the same problems.
Pls, any ideas?
could be related with some transmission problems? gear box malfunction?
V70-98 strange problem.
- Has thanked: 17 times
- Been thanked: 35 times
Hmmmm, 4th injector circuit malfunction....could be intermittent. Check the relay on the fan shroud...on the passenger side (front of the car)...it's the one that sends the signal to the injector. Could be bad solder....cold there's contact, as it warms, solder expands and causes a break, but as it gets even hotter, the expansion completes the circuit again. This is just a guess.
Maybe others will chime in with some other across-the-web diagnostics.
anonim2007
- Year and Model:
it is quite strange,
where are this relay located?
cause I looked at wiring diagram and didn't figure an injector relay.
all the injectors have two wires:
one give them 12V from a junction point right after the fuel system main relay passing the 11B fuse
the other one came directly from computer, one wire for each injector.
edit: I remember to have one of this relay on 850, but on V70 didn't find it.
chuckcintron
- Year and Model:
'Loping', or cycling up and down within an rpm range (800-1100rpm) can sometimes be caused by a vacuum problem, or a problem at the throttle body. I'd check the idle control motor.
Also, there's a chance that the mass air flow meter could be defective, sending the incorrect flow data to the ECU, and causing the computer to modulate the throttle incorrectly.
-Chuck
-Chuck
1997 855GLT
anonim2007
- Year and Model:
did someone know where to buy a ECU (the main computer) for the above car?
preferably used, not new.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Do not buy an ECU, that is not your problem. Go back to the #4 injector. Check the wires very closely, they may be shorting out where they go into the cap. Also clean the electrical plug while you are at it.anonim2007 wrote:did someone know where to buy a ECU (the main computer) for the above car?
It gets very hot, so do this while the engine is cold.
Klaus
Klaus
