Brake bleeding procedure '87 740 GLE Wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ccb222
Post by ccb222 »
I have replaced brake master cylinder so assume I should bleed all four brakes. Chilton manual describes the procedure, but does not say whether to do it with the engine running or not. Quick answer appreciated! Also, Chilton says there are three bleeders on front and I can only find two (Bendix calipers). Thanks--Charles (ccb222)
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You don't need the engine running as you don't need the servo when bleeding brakes.
Volvo used ATE, Girling and Bendix calipers. I'm not sure which one of the three has 3 bleed valves but two of them only have 2 so we can assume Bendix was one of them. If you should find a third then it is imperative that you open all three together.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
