I'd appreciate any help/advice. Am I getting in over my head, if I don't have a manual?
99 s70 cv boot replacement
Putting a Value on a T-5R
I'm going to attempt replacing right side / inner and outer cv boots. I can't find any information on this job anywhere. There doesn't seem to be a Haynes or Chilton book on the 99 s70. I can't find anything at my local library. I've asked my local Volvo dealer about a shop manual, but they aren't interested in selling me one. Is there a good source for how-to and also any special tools that I may want to get before starting the job?
Tip the world on it's side and everything loose will end up in LA. FLW
- Year and Model: Many Volvos
- Been thanked: 76 times
It is often preferable to simply replace the axle, particularly is the boot has been bad for a while and subjected the CV to the elements. I've never had to change one but MIJ always recommends raxles.com. I think they are in the $100.00 a pop range.
MrWinkey over on VS did a write up on the boot change here:
http://volvospeed.com/Repair/cv_boot.html
I would highly recommend that you at least pick up a Haynes manual, don't get a Chiltons, get a Haynes.
Did a search on matthewsvolvosite but I only found lots of questions from others about cv joints. Am I doing something wrong when searching?
I'll try volvospeed. thanks
- Has thanked: 17 times
- Been thanked: 35 times
If you're going to do it yourself, just replace the axle. Actually raxles is a bit more expensive....about $160 or so after core replacement. So much trouble and so messy to take the joint apart and clean it, repack it and put the boot on. But if you insist, then eeuroparts.com has a good deals on the boots...forgot the name but it's a German manufacturer. Either replacement or repair, the axle has to come out anyway, unless you want to sweat laying under the car with the axle supported as you take it out of the wheel side (assuming it's the outer boot that's ripped) and then take it apart and clean it and repack it (still supported and you on your back), best done with special tools too. Otherwise, it comes out completely and you do it on a bench...still a royal pain.
There are write-ups on Volvospeed but to get the axle out you have to shove two large slotted screw drivers or axle tools into the spline area where the axle enters the transmission and pry the axle out by compressing the circlip. This can be very frustrating if you've never done it before. If they are original axles, there will be adhesive holding the axles in as well making it extra hard. Make sure you get an axle seal too in case you bugger it up when you take the axle out. No need to use adhesive when you put the axle back in unless you just really want to. To get the axle back in, you shove it in until you hear the circlip snap into place. This is all after taking the axle out of the hub and ball joing (control arm or a-arm) off the end of the axle. Anyway, best to see some pictures with descriptions than reading what I've written.
madeinjapan.
Thanks.
This is exactly the kind of info. I needed. Not having done this work before, I wasn't sure what I'd be in for and I figured I'd hold off a few days just to get some input from a knowledgeable source. I'm glad that I waited because this sounds like it really is more than I want to get into right now. I'll be taking it to my trusted garage for this job.
Thanks again.
Thanks.
Thanks again.
pfeener
- Year and Model:
- Been thanked: 2 times
If you're going to have it done, the only method that makes sense is to replace the axle. The extra labor you would pay to have the boot done would cost as much as just swapping the whole axle.
MadeInJapan,
Are you saying that a circlip needs to be compressed before the axel assembly can be removed from the transmission? I've replaced the CV joint/axel assembly on other cars and the axel was easily pulled out of the transmission without any trouble. Does my 850T automatic have a circlip that retains the axel in the tranny?
I looked at the 850 manual and it doesn't mention a circlip to remove the axel but it does talk about a circlip to service the CV joint. If this is true, when I replace the whole axel assembly I won't have to fool with the circlip. Is this correct?
Sorry for the repeated questions. Trying to make sure I can do this job without to many !%@*&^#'s.
Thanks,
Mr_dave
Thanks,
Mr_dave
pfeener
- Year and Model:
The LH side has a cir clip, but it's nothing you have to compress or remove. It works the same as all the other cars you've worked on. You need to apply enough pressure with a pry bar to overcome the clip holding the axle. The RH side has no clip. Once the intermediate bearing cap is removed the axle will slide right out.
Thanks for the clarification. I guess I shouldn't have said "compress the cir clip," but you do have to give the axle enough force to overcome it on the left side (driver's side for those of us in the U.S.). The other side is a piece of cake to get out.
- 11 Replies
- 5973 Views
Last post by default
- 920 Views
Last post by CThompson
- 762 Views
Last post by boneman131
- 1658 Views
Last post by rocketman4321
- 3130 Views
Last post by foggydogg
