91 940 turbo wgn gear shifter problem
PArked car in driveway, shut it off. Started it up later in PARK, gear shifter loosely "floated" between gears and won't "catch", always in neutral. putt on emergency brake and removed plastic coverings to expose the gear shifter. Found a broken thin piece of black plastic floating on side of gear shifter. Shifter will move from Park when top button pushed down on shifter, but engine doesn't correspond, remains running in neutral. HELP!
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Unfortunately your link to Image Shack does not work. Would you try again, please?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
Yes, that worked.
It looks like part #25 on the attached. This is part of the shift lock mechanism. Part #26 is the manual release.
The note says up to year '91 for the part number.
The second attachment shows how it all fastens together.
Hope this helps.
Bill.
Hope this helps.
Bill.
Previously:
Previously:
- billofdurham
Glad to help but all manufacturers are the same - you need to buy too much to get what you need.
Have you tried http://www.erievovo.com/. I have no personal experience as I live across the pond, but others have found them helpful. Apparently a telephone call is better than an email.
Bill.
Bill.
Previously:
Previously:
- billofdurham
That is about it if you are talking about the complete assembly, lever, selector gate etc.
One point - the lever was changed in 1993 so it will not fit into your car.
Bill.
Bill.
Previously:
Previously:
