A/C clutch won't engage on 1994 940 wagon
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bentrider
Post by bentrider »
The a/c quit working a few days ago and I noticed the clutch does not engage. I did not see a blown fuse. The fan does work. Anybody have any common things to look for when this happens?
Thanks,
Joe
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
After fuses the first thing to check is the refrigerant charge in the system. Is there enough in or is there a leak?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
bentrider
Post by bentrider »
Bill,
Whats the best way to test the refrigerant with the system not working?
Joe
billofdurham
Over here, where our 'nanny government' has banned the sale of refrigerants to individuals, we have to go to an authorised shop to have it checked.
In the US you can buy canisters of freon to top up your system. This would tell you if there was a leak.
Check out the Official AC thread in the Volvo Repair Database on this site. It is full of tips and advice.
Bill.
Previously:
bentrider
Post by bentrider »
Bill,
After I posted on this earlier, the a/c started working again, then the car died due to a bad rpm sensor. Does the on board diagnostics also detect a/c problems?
Thanks,
Joe
billofdurham
The diagnostic unit in the engine bay only stores fuel and ignition faults.
On cars fitted with the Electronic Climate Control system fault codes can be read using the ECC unit but I believe that the '94 940 was fitted with a Manual Climate Control. I know that my 940 was. Therefore, it is not possible to read codes for the AC.
Bill.
Previously:
bentrider
Post by bentrider »
Bill,
Thanks for the help. Now for some reason the clutch is cycleing every 5 to 10 seconds. I guess it is time to to add the 134a again. Could a faulty pressure switch cause this too? Thanks,
Joe
goldmember
Post by goldmember »
G'Day
I'd say the fault lies with not having enough pressure of gas. That is, you need to re-gas. This pressure is required for the A/C to engage. Otherwise the belt just turns the pulley, virtually, resistance free.
Correct me if I'm wrong, but the pressure switch is used to turn the A/C fan on. THe reason I suspect this is that a wrong pressure switch was installed in my 740 and the bleeding fan comes on all the time, regardless if I have the A/C on or not.
Apparently this is not an issue and to replace the switch means a re-gas, so I won't be doing that for a while.
I hope you have your problem sorted out.
Regards
George
Gold Member is our Gold 91 740 Wagon
