Secondary Air Intake Induction???
Red Brick
Post by Red Brick »
At elast that is what I think the kid with the OBII said it was. My check engine light came on this weekend in Ellensburg while I had it idliing to warm up. I had about 6 inches of snow covering the whole car, so I just figured it had something to do with that and it would go off. It was still on the next day when I got back home to 57 and raining. The kid at Schuck's reset it and it hasn't come back on.
Do those lights always need to be reset and if you reset it and it stays off, does that mean the problem is fixed? The car never skipped a beat.
1998 Volvo V70 GLT
2003 Dodge 2500 Quad Cab Diesel
1966 Ford Mustang Convertible
1951 Willys CJ3A
2001 Lund Pro Sport
2007 John Deere 3120
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Some do but others don't. If it's reset and doesn't come back on, count yourself lucky. Maybe the air was restricted with all the snow on it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
CE light isn't always trouble. Many things can cause it, from an injector harness being loose to washing the engine at a car wash (not recommended). Mine came on a few weeks ago after a Motorvac treatment.
After popping the harness back on properly, and a drive cycle*, the light went out.
And then there are the non-trivial triggers for this light, like a toasted O2 sensor (code 2-1-2). The light will not go out until you change the sensor.
* a certain number of miles or minutes spent driving. I've ridden out two drive cycles, and each took around 50 miles and two days.
Also -> Amazon link
