Overboost, 854 T-5R 1995
- Has thanked: 17 times
- Been thanked: 35 times
First time I've heard of "over-boost" on these cars. Who makes it and how does it exactly work? Without this info, it would be hard to help.
You're just talking about the turbo coming on. I had actually never read that. So you're saying that the turbo doesn't come on like it should? Check your turbo hoses. I would be willing to bet that one has slipped off or one has a tear in it. Good luck!
Necromancer
- Year and Model:
The overboost is controlled by the computer which has different programming than a standard T-5.
I would think that the computer would manage the bypass valve in the same manor as a T-5 but allow the extra 30 seconds of boost on a T-5R.
Very interesting...it's good to learn something new everyday.
Necromancer
- Year and Model:
I did a little research on this before thinking I could turn my T-5 into a
T-5R
What I found wasn't conclusive so I'm still not sure that you don't have an extra hose running to the turbo that I do not have.
As far as I can remember, I have three small vacum lines that run from the area of the air cleaner box to the turbo.
Perhaps you have a fourth and it fell off or has a leak?
I also know that it's criticle (at least for performance) that these lines are connected up correctly. Perhaps you had someone service the car recently and misplaced these lines?
Do a search as I remember there being a diagram on this site on how they should be connected.
T-5R
Necromancer
- Year and Model:
The only other thing that I can suggest is to 'shut down the system', i.e. remove the negative battery cable for a few hours.
This should reset the computer(s) and might be worth a shot.
Make sure that you have your radio code as you will need it once you reconnect the battery.
